Cannot Find Source of Amp Crackle
Re: Cannot Find Source of Amp Crackle
plate resistors on the extra gain stage in the reverb channel!!!
Problem solved!!!
v4 voltages back to normal
The amp is really gainy, surprisingly enough... When i first got it about 6 years ago... it had stock preamp tube set with sovtek 5881's and a 5ar4 rectifier tube. I took out a 115k and a 130k plate resistor out of the reverb channels first gain stage. and there were some lower valued cathode bypass caps in some spots- like a 4.7uf and a 2.2uf. everything else stock values AFAIK.
it used to be SUPER clean and SUPER LOUD- I mean headroom for days with a les paul. I never got gain without a pedal.... with 5881's. The amp also didnt sound as good as it does now... not even close. it was sterile and flat. now it's warm and punchy and chimey- great shit here.
I'm wondering how it could have behaved like that... and how 5881's could have even survived with the high plate voltages a 5ar4 makes in this amp. Could that have just been super cold bias?
Thanks to you all the amp sounds great now!!! I mean really, really good. Thanks so much!
Problem solved!!!
Congrats!
Now take the rest of the day off.
Great news about the amp. Enjoy!
anyone got any idea why it has so much less clean headroom than it used to?? could that be bias alone? i mean it had 5881's! they were sovtek's though, so i guess they could be more like 6l6's. but i mean it had the 115k and 130k plate resistors! it used to be like i couldnt get any dirt at all with my humbucker epi les paul that was decently high output. but i could with my danelectro because the pickups were so much weaker i was able to turn the amp up to 8 and get a very moderate tube breakup... weird
Just a guess, but if all tou changed was the plate resistors, if the old ones drifted and produces less gain at each stage perhapsmthat is an explanation? I don't have much experience with resistors drifting in value so notmsureifnthat is even viable...
what does that even mean? english is preferred.surfsup wrote:Just a guess, but if all tou changed was the plate resistors, if the old ones drifted and produces less gain at each stage perhapsmthat is an explanation? I don't have much experience with resistors drifting in value so notmsureifnthat is even viable...
I have replaced every component in this amp in the past 3 months. the only mods to the measured original components were the plate resistors were like 120k but measured at 115k and 130k... i didnt measure anything else that had drifted too far outside its tolerance if at all. granted I didnt measure every single part I removed. But whatever, is there anything that would even give you that much more headroom?
Caveing,
If you want to get picky about grammar and punctuation, I counted 10 errors in your last post.
- statorvane
Yep. It took me a couple of weeks to find this was causing similar problems on a clone JCM800 build for my son. The way I eventually found it was chopsticking around. Initially it sounded like I had microphonic wire, but it was a loose solder joint on V1. Listen for some noise when you choptick the wires, and fi one stands out, trace it to its solder joints.Another possibility is a bad solder joint.
Could also be a tube socket - loose pin somewhere in the vibrato channel.
Good luck, and hope this helps.
In my limited experience those old carbon comp resistors usually drift upwards in value.
Sorry, i'm from kentucky and am definitely not exposed to correct grammar very often--i also dont associate with people that give a shit about grammar-- i honestly just didnt take the time to translate his post- i really had no idea what he was saying. but now i get it.Jana wrote:Caveing,
yeh plate resistors have always drifted up on me. why i'm wondering how the amp had so much more clean headroom a few years ago... that thing was LOUD
Being from Kentucky is nothing to be sorry about.
If it was cold biased before, then probably lowered B+ voltage to the preamp some when you biased correctly (power tubes now draw more current). Lower voltage in the preamp usually = easier overdrive.
Plus the 5ar4 rectifier... that increases preamp voltages an increases headroom right? I'm wondering if I could pull some extra clean headroom.thejaf wrote:If it was cold biased before, then probably lowered B+ voltage to the preamp some when you biased correctly (power tubes now draw more current). Lower voltage in the preamp usually = easier overdrive.
Are sovtek 5881 wxt's true 5881 tubes? I'm thinking I could have some 5881s and the 5u4 with my single 12" speaker for low headroom.. and I could thow in sme 6l6gcs and a gz34 with cold bias and a 2x12 cab with my cannabis rex speakers for increasing the headroom... seems like that might change my clean headroom quite a bit
