Yep Guns and Gold......barter and then just take the rest.Reeltarded wrote:Go build an engine and a firearm...
Then you can drive to where they are and have them for free.
TM
Reeltarded wrote: ..............
I am better at finding burned spots anyhow..
Reeltarded wrote:Awesome!
About the bias, I think the range is too short, and another set of similar tubes would make you have to change the range one way or another to stay in that narrow one you have. I am not all about sticking a pot outside to adjust the bias like that on an open Marshall style (right side up, not like those pesky Fenders!) the other thing to consider is you are getting 400 at the plates, but then you change the bias, and now you aren't sure of your plates from outside.. Which is a minor consideration if it's your amp, you get a feel for what you are dealing with after a few runs at biasing.
I would prefer a +/-10mA setup, that is wide enough to swap in similar tubes of many brands/vintage. The RFTs I found go up by 5-8mA over all my current production stuff in my 50. Just thinking.
RAWKIN'! Congrats!
Oops. 1/2w fine in bias.
