No problem!jmohr58 wrote:Thanks for the advice Colossal.
You've been a great help.
Check the tonestack graph again (post above). Making C2 smaller lowers the gain slightly, shifts the mid "scoop" and will let a bit less treble through. Making C2 larger gives a boost in mid and treble frequencies so you hear a bit more of a mid focused shimmery kind of tone; maybe more complexity is a good description. Of course this depends a lot on the amp, where the tonestack is in relation to the other gain stages, etc. So if by darker you are meaning a bit of treble cut, this is one way you could realize some. But yes, the landscape is multivariate here so brightness doesn't just come from one place. You can attenuate at the input or in other places as well or a bit of both.jmohr58 wrote:On C2 increase, since I am placing an order was just wondering on this for the future if it was justifiable and if my line of thinking was correct that if lowering C2 made it brighter than higer values would make it darker. Your response allowed me to understand that C2 changes aren't that simple and more is going on behind the scenes.
Lowering that 100k mid slope resistor down to 33k will have a nice treble cutting effect so listen to that one first before judging C2. I would go with 33k/500pF or the other plexi standard is 56k/250pF.So it looks like I will be ordering parts again in the future possilby so I will hold off on C2 for now.
Yep, something to consider. For now I'd concentrate on just getting the tone closer to what you are after then add the bells and whistles. You might really like the effects of bumping the output tube's cathode bypass cap up from 22uF to 1,000uF (or even higher). Something to keep in mind after you go through the first round of tweaks.I like the looks of the Mod you have drawn up and will be something to add a bit more complexity to the overall tone of this amp. In the future of course.
Well, there should be some good ale around so hopefully that will provide some solace for the loss of the weekend. Play some Down By Dun Ringill by Tull and sip some fine ale!Well have a good weekend, the wife is dragging me out to an SCA event. It's the Ceilidh weekend, (pronounced Kaylee's or so I think) so much for a quiet weekend at home.
