Octal Deluxe
- Lonely Raven
Re: Octal Deluxe
Now that you got that sorted out, you have a layout or Schematic? I'm curious to see how you implemented the octal preamp tubes.
Jack of all Trades,
Master of None
Master of None
Re: Octal Deluxe
Weber Proluxe maybe?
- Noval_novice
Re: Octal Deluxe
I think Weber's Octal Proluxe uses grid leak bias. All I did was use the octal preamp tubes without changing the cathode biasing of the 5e3.
Here's a schematic. Be gentle. I am still learning this crap and sure there are errors.
Re: Octal Deluxe
Your taking your outputs off the HV B+ instead of the plates.
- Noval_novice
Re: Octal Deluxe
Sorry. Didn't understand you.
Cliff Schecht
Re: Octal Deluxe
Lol he's right, your schematic is wrong. The signal coming out of each tube gain stage should be after the 100k plate resistors. What you have drawn won't work.
Cliff Schecht - Circuit P.I.
Re: Octal Deluxe
What the above gentlemen are saying is, that you should take the signal going FROM the tubes at the tube's plates, and not above it's plate resistors.
Also, the boost-switches you have on the cathodes of the first tubes - install two, say, 100K resistors in series with capacitors C1 and C2, and make the switch short out those resistors. That way you'll avoid some nasty popping from the capacitors not having a steady voltage reference when switched out.
It's OK to be new, don't worry about it, that's what we're here for. Everyone has a question and everyone knows something.
Jake
Jake
Re: Octal Deluxe
Cliff I can't just let that one go. This guy is a newb and said there would be errors. "lol" is hardly encouraging. "your schematic is wrong" doesn't help. He built the amp and it works for fuck's sake. We've all been there, you too. Think about it.
- Noval_novice
Re: Octal Deluxe
Ok, I see. Yeah, that's not right. I will fix the schematic when I'm done with work today. Looks like I also placed my power switch in the wrong place. I will also add the resistors to the boost capacitors. Hadn't tried placing different cathode capacitors on a switch before. It pops but not loudly.
Ian, no worries. I wouldn't post here if I didn't want to be corrected.
Re: Octal Deluxe
Hey you stole my line
for fuck's sake
Cliff Schecht
Re: Octal Deluxe
Only reason I said lol is because I looked at that schematic earlier and didn't notice the plate resistor error. It seems my attention to detail has waned since things are getting hectic for me these past few weeks..
- Noval_novice
Re: Octal Deluxe
Ok, here is an updated schematic. Thanks for everyone's input. I'd be lucky to make anything work without the help from this forum!
Re: Octal Deluxe
Really, put a 5K across R24 and R25. This will give you about 4K and 2.4K instead of 18K and 4.7K. You'll get a decent boost in preamp voltage. It will increase your headroom and give you a bit more gain, as well. If you don't like it, you can simply remove them.
- Noval_novice
Re: Octal Deluxe
I may try that. Thanks, Phil.
Re: Octal Deluxe
I gonna making same using your schematic. Are you still happy? Have you changed something? Maybe i try 6SN7WGT phase inverter. And 6AK6 power tubes for bedroom level.Noval_novice wrote:Ok, here is an updated schematic. Thanks for everyone's input. I'd be lucky to make anything work without the help from this forum!
Seppo
