vvr problem
FYL
Re: vvr problem
Post by FYL »
I just implementing VVR in my express, but can’t decide between heat sink out of chassis, and cooling direct on chassis.
If your build uses a standard aluminum chassis, direct mounting is OK (using suitable insulation, etc.). You may add a heatsink if you wish.
Kagliostro
Re: vvr problem
Post by Kagliostro »
Hi FYL
Mosfet to insulator to chassis, with the latter dissipating heat
thanks
my answer was because a 2mm thick ceramic insulator between mosfet and heat sink or chassis seems to me to be too thick and don't help the heat dissipation
isn't better a conductive paste and insulate the heat sink ?
Kagliostro
FYL
Re: vvr problem
Post by FYL »
The insulator acts as a coupler/spreader. Thick aluminum (or beryllium) oxide insulators are the norm when it comes to high voltage/hich frequency apps.
For instance the standard Aavid Thermalloy 4180, perfect for TO-247 components such as power mosfets, is app. 2mm thick.
This would be very dangerous. You should always insulate at the component level.
