dr z mazerati gt
Re: dr z mazerati gt
Maz GT is a vox AC30 w/o a tone stack, or anything else 'fancy'. Someone had to say it, right?
funkmeblue
say what? Z just told us about the topology of maz gt.
Well the Doc used to be very active in amp building forums years ago and I think he misses the interaction maybe.
Doc, tell your lawyer that your going to start selling Zwreck kits wether he advises it or not.
Yes the technical interaction is nice.
I enjoy the give and take, I appreciate learning something new.
I'll help out , but no kits, I don't have enough phone time available to support it.
DR.Z
DR.Z
Doc,
On the Maz GT is the grid resistor on V1b anywhere from a 10K to 68K? Some amps don't use any in that spot but the Maz GT appears to have a grid resistor off the tube pin coming off the wiper of the pot.
That is a 820 Ohm oscilation suppresor.
Must be mounted on socket pin.
DR.Z
DR.Z
Thank you Mike.
An 820R suppresor, I was assuming that it was in the 68K to 100K glad I asked.
I'm going to order a Heyboer PT 300-0-300 250mA 35w rating, 5v and 6.3v and the Dyanclone A-470-S OT 4k3, 4/8/16 35w rating and get started on my version of a Maz GT should be fun. This one is going in a TW cherry cab a little wider than usual as the Ken Watts chassis I am using is 17.5 x 8 x 2.5 plenty of room to work in. JJ can caps and eyelet board. Rather than a MV I'll use the watt control at the tail of the PI.
That all sounds good Mark.
Have a ball, just remember with that much gain, keep your leads short, and watch transformer placement.
Z
Z
Thanks Doc,
That Brian May AC30 is very similiar no tone circuit just all gain.
The Dave Petersen version:
You wouldnt happen to have that in a format other than png would you?
TT
TT
Is gif OK?
The Doc is being awesome! What if every established builder was this nice. wink wink.
Hey Dr. Z, Bill Zumwalt here . remember me? from Alaska. Great to see you here. I moved to Austin a few years ago and setup shop.
I just worked on a Maz jr some idiot did some funkyness to. It is sounding Killer now .
[quote="billyz"]Hey Dr. Z, Bill Zumwalt here . remember me? from Alaska. Great to see you here. I moved to Austin a few years ago and setup shop.
[/quote]
Great Bill welcome back to the lower 48.
Thanks for fixin' up that JR before someone from TGP played it : )
Did you open a store ?
Z
Z
