5e3 problem - low output!
rogb
Re: 5e3 problem - low output!
Post by rogb »
I gave up on page 2....
When I was starting out I listened and followed the advice of my betters on here, some busy pro builders who took time out to advise, to the letter. Problems were solved so quickly.
ben85
Post by ben85 »
V1
ben85
Post by ben85 »
V2
ben85
Post by ben85 »
V3
ben85
Post by ben85 »
V3
ben85
Post by ben85 »
V4
ben85
Post by ben85 »
V5
tsutt
Post by tsutt »
Clean up with alcohol and a small brush. pin 5 v2 is a cold joint do see the solder has not flow to the wire. it molded around it. and people need to full shots of the whole chassis. is there any near where you live that has knowledge of amps the can go over the wiring. theres not a whole lot to this amp it should be fairly easy to figure out.
ben85
Post by ben85 »
input
ben85
Post by ben85 »
a.
ben85
Post by ben85 »
pots
ben85
Post by ben85 »
whole chassis
ben85
Post by ben85 »
whole chassis
ben85
Post by ben85 »
ok tsutt,thank you,i'll clean and fix v2 pin 5 right now!
NickC
Post by NickC »
ben85 wrote:input
In the future, if you're going to have long component leads in close proximity to other components (like those of the resistors wrapping around the input jacks), you should sheath them with some wire jacket (aka spaghetti) or shrink-tubing. Sometimes arcing can be a problem.
