turret
mark enger
turret
is there any thing i can use as turret something one could buy local. iv got a box of old tube pins i got at a yard sale. they look like they'de work. any ideas???
Re: turret
Mark,
I have no idea what you're asking (nor for the diode question). Maybe I'm tired, but could you perhaps be more clear?
mark enger
Re: turret
im asking for thing to solder to make preamp boards.
Re: turret
You can use 1/8" eyelets instead of turrets. If your board material is 1/16" thick. Eyelets are what Fender used to use. and they are cheap. You should be able to find them at Michaels Craft store. for about 2 or 3 bucks per hundred.
Re: turret
Make sure they are not aluminum eyelet. Brass or unpainted tin will work. I use the brass ones from a sowing supply store. The ones used to make women belts. They are a little large and take a lot of solder but work great for old fender type complexity circuits.
Re: turret
And at fabric shops and scrapbook storesmcrracer wrote: ... find them at Michaels Craft store...
Instruction here:
http://www.eham.net/articles/16053 About half way down the page.
Pictures here:
http://home-and-garden.webshots.com/pho ... 2884zczLBG
Tim
