Hi guys and gals.....long time no speak...been outta touch.
A long time ago, a guy listed a layout for a small practice amp that used two 12ax7 s for the pre and a 12au7 for the power section. Can anyone remember what it was called?
Thanks as always....
Brian
Heavy Watter Question?
Re: Heavy Watter Question?
Firefly?
It is not the Firefly. I remember that it used a reverb trans from a Fender for a power trans. But thats all I can remember
Moonlight?
Might this be what you are looking for?...
Thank You!!! Problem solved.
Can I use a 4 ohm speaker pair (two 8's) with this amp, or will that combo hurt it?
Brian
Brian
Wouldn't "hurt" anything, but you may want to consider using a hammond 125a, b, or c SE "universal" OT instead of the Fender Reverb OT if you want the flexibility of multiple impedance taps. HTH
PS- Here's a layout for tha amp in question...
