Installing tube screamer petal guts to amp circiut
Does anyone know of any good references to taking the guts of a tube screamer and adding it to the control panel on an amp. Questions: How do you supply the 9 volts or can you mod it another way? How would you add a noise gate petal in the same manner - having the petal circuit inside the anp just like the tube screamer?
									Rookie with Determination
						Re: Installing tube screamer petal guts to amp circiut
I've thought of the same thing...eons ago.
I finally figured out it's best to have the tubescreamer right where it belongs.
On the floor, and portable.
all you need to do for the voltage supply is use a 2 - 5w dropping resistor from the screen b+;  maybe 100k - 150k  for value.   then use a 1w 9v zener and filter it on that end with maybe a 47uf - 100uf  cap.   now how you mount the guts, do the switching, etc. is up to you and your own particular chassis.    rh
