Squeal
Squeal
I have a new Plexi 1987 build that has pin 2 and 7 jumped on v1 and a ppimv. If I turn the master past 3 i get a squeal when I turn the bright gain past 6-7. Not loud but a squeal all the same. It sounds like something is getting overloaded with signal at 6-7 and the squeal begins. No guitar or with the guitar is no different.
Re: Squeal
Ummm. We're going to need a bit more to go on. All I can say with confidence (at this point) is something is kerflooey.
Re: Squeal
How about a picture on how the PPiMV was implemented?islandamp wrote:I have a new Plexi 1987 build that has pin 2 and 7 jumped on v1 and a ppimv. If I turn the master past 3 i get a squeal when I turn the bright gain past 6-7. Not loud but a squeal all the same. It sounds like something is getting overloaded with signal at 6-7 and the squeal begins. No guitar or with the guitar is no different.
Using shielded cable? which version did you use?
