Mark wrote: ↑Tue Sep 23, 2025 1:38 pm
Have you tried cleaning the boards and removing the wax. Lyle Caldwell claims it fixes the issue, though from my experience there was a slight amount of voltage conducting through the board.
I had seen his videos & DID try cleaning, then deep cleaning, but no luck. They were really, really caked with wax & I could never eliminate the stray voltage, so I replaced the board (have only done one so far).
I even used heat to remove the wax and while it helped, it wasn’t the cure. The ugly cure is to use tag strip to isolate parts from the board.
ampdan wrote: ↑Thu Sep 25, 2025 8:18 pm
I slapped this together with parts I had available for a local Blues Jam back line.JPG[/attachment].[attachment=1]IMG_2644[1].
Dan,
Very nice looking build. What kind of carbon film resistors are those?
IMG_2644[1].
[/quote]
I love the 2x10 speaker option. It sounds so much better than the 1x12 I was using. Here's mine:
I slapped this together with parts I had available for a local Blues Jam back line.JPG[/attachment].IMG_2644[1].
