Channel Switching AFTER the Phase Inverter?
Dr Tony Balls
Post by Dr Tony Balls »
Hi All,
A friend asked me recently if it would be possible to build a two channel amp where one is 5E3-ish and one is Pro Reverb-ish. Obviously on most two-channel amps the phase inverter is shared and thus the signal is blended before the PI. These two circuits, however, have very different PIs so sharing a common one would not be possible/reasonable. I'm wondering if this sort of thing could be done with a switch AFTER the phase inverters? Basically each preamp has its own phase inverter with a DPDT switch after that selects which channel goes to the power tubes. I'd probably place a coupling cap before and after the switch to avoid any DC on the switch but does that sound feasible? Any pitfalls i;m not thinking about?
I build effects and amps and do custom builds to order. Boom.
Site: http://ballseffects.com/
sluckey
Re: Channel Switching AFTER the Phase Inverter?
Post by sluckey »
It's possible. Is it a good idea? I don't know. Makes me wonder why I've never seen it before. Give it a try and let us know what you think.
pdf64
Post by pdf64 »
But the output stages are rather different too, 5E3 being cathode biased with a saggy screen grid supply, Pro Reverb fixed biased with a stiff screen grid.
Then how about the reverb, I suppose he'd want that in the 5E3 too?
A request for a fx loop may not be long in the offing :)
Dr Tony Balls
pdf64 wrote: Tue Aug 12, 2025 5:24 pm But the output stages are rather different too.
I know, but those are details for another conversation. For the sake of discussion we can pretend the two amps I mentioned were an Orange OR120 and a Marshall 1959. The point is determining if there are pitfalls to switching in this location.
sluckey
Post by sluckey »
Dr Tony Balls wrote: Tue Aug 12, 2025 7:13 pm For the sake of discussion we can pretend the two amps I mentioned were an Orange OR120 and a Marshall 1959. The point is determining if there are pitfalls to switching in this location.
Jumping from 5E3 and Pro Reverb to orange and Marshall is quite a jump! There are no pitfalls but you need to consider how you will switch the NFB. You'll probably need more than just a DPDT switch.
Dr Tony Balls
sluckey wrote: Tue Aug 12, 2025 9:11 pm Jumping from 5E3 and Pro Reverb to orange and Marshall is quite a jump!
Ha....for comparison sake i'm just saying to focus on cathodyne vs LTPI and how to switch between the two of them.
sluckey wrote: Tue Aug 12, 2025 9:11 pm There are no pitfalls but you need to consider how you will switch the NFB. You'll probably need more than just a DPDT switch.
Excellent point!
