I know Ken Fischer and subsequently Gerard Weber were fans of earthing the braid of co-ax on the plate/anode of a 12AX7. Though in Ken Fischer’s case he used this wiring of co-ax on the second triode which would result in only damage to the volume pot.
There are others who claim the voltage on the plate/anode can get on to your guitar and cause electrocution. I could be mistaken but I think that the voltage is more likely to damage your pickup rather than electrocute the player.
At this point in time I think I would prefer a small value cap from plate/anode to the cathode.
What is the general consensus out there?
						Earthing the braid of co-ax on the plate.
									Yours Sincerely
Mark Abbott
						Mark Abbott
Re: Earthing the braid of co-ax on the plate.
This practice is giving an A.C. path to ground through the power supply node.
It also acts as a capacitor, providing mild feedback, as the phase of the plate signal on the shield is 180° to the grid signal.
I trust teflon coax, but i think on the first stage, the risk would be too great.
I've also never needed to this technique combat noise, YMMV.
this is to tame high frequencies in high gain with 100-200pF value of capacitance in coax cable.. not technical method, nor smart idea, better to use some ceramic 100-200pF 1kV if needed
                                            2 others liked this
The small capacitance is in parallel with the internal Cg-a, so it gets multiplied by the gain (Miller effect). Even if the cable capacitance is only a few pF, it will cause a significant HF roll-off. The same effect can be had by placing a snubber cap from plate to cathode, say 200-400p.
Thanks for your replies. I thought much the same. I estimate the capacitance from a two inch piece of co-ax to be in the order of 10pF. Even with Miller’s effect I doubt it would be all that effective.
									Yours Sincerely
Mark Abbott
						Mark Abbott
                                            5 others liked this
Let's say 2" of a low capacitance 20 pF/ft cable is used. That's 3p3. Here's the result for a typical Fender 12AX7 stage with 34k Rg, 100k Ra, 1k5 Rk, 22u Ck with and without 3p3 Cga added. The -3dB point drops from ~22 kHz to just over 7.5 kHz (not 5kHz).
Edit: Corrected an error in the model which raises the -3 dB point for the case with added Cga. Also note in both cases the input signal has 39k source impedance.
					Last edited by martin manning on Mon Jul 22, 2024 11:15 am, edited 1 time in total.
Thanks for illustrating the difference between the two outputs. I’m surprised that 3p3F makes that much difference.martin manning wrote: ↑Sun Jul 21, 2024 11:52 amLet's say 2" of a low capacitance 20 pF/ft cable is used. That's 3p3. Here's the result for a typical Fender 12AX7 stage with 34k Rg, 100k Ra, 1k5 Rk, 22u Ck with and without 3p3 Cga added. The -3dB point drops from ~22 kHz to just over 5 kHz.
I know the top end of my hearing has rolled off over the years (doing a quick test of my hearing I hear 8Khz okay but 10Khz is quite difficult), and I guess it’s expected that I didn’t hear any difference when removing the co-ax cable.
Yours Sincerely
Mark Abbott
						Mark Abbott
See my correction above, which seems to make the simulation result line up with your observation a bit better (-3 dB at 7.5k). The effect will of course increase with longer cable runs, such as from the front of the chassis to the tube pins, where the length could be 7-8 in. Six inches, 10p added Cga, brings it down to 3.2 kHz.
