I have been wanting to have the same quality as Hiwatt builds with the kink in the component leads. Do you guys know where I might be able to find such a tool?
This is what the tool looks like. DigiKey use to sell them.
Thanks for your assistance.
						Looking for this tool
									Yours Sincerely
Mark Abbott
						Mark Abbott
				sluckey
		Re: Looking for this tool
Hakko has several lead forming tools. Here's one...
https://www.tequipment.net/Hakko/PNR-30-D/Pliers/?v=0
If not the correct one just search for electronic component lead forming tool.
This is the reply from TE when I tried to purchase the tool.
“ Hello,
We thank you for this request, however, the Manufacturer will not allow the export of this equipment.
Please select another brand.”
They aren’t making it easy.
									“ Hello,
Yours Sincerely
Mark Abbott
						Mark Abbott
I purchased a bunch of Hakko stuff from amazon.jp a while ago when the conversion rates were favorable. Perhaps you could find one there, or some other Japanese store? I bet shipping is cheaper than ordering from the states.
				sluckey
Do a google search for "Hakko PNR-5000-D Lead Forming/Cutting Tool". This is the exact one in your posted pic.
Thanks for the tip. I’m chasing that up now.
TE got back to me and suggested Excelta 554TB-US - Stress Relief Forming Plier, 5.5", Carbon Steel which cost $252 as opposed to $30.00
I don’t doubt the Excelta stuff is good, it’s a lot to pay for such a tool.
Yours Sincerely
Mark Abbott
						Mark Abbott
FWIW there's a goot (brand--Taiyo Electric Industries) YP-201AS that shows up on Google searches (here in Japan) which appears similar (same?)  :
https://en.goot.jp/products/detail/yp_201as
Also, this one showed up via Google image search, a "Piergiacomi PTR30L (the original Italian maker/brand?)" (relatively close to you in NZ but unfortunately none avail.) :
https://www.baskiville.co.nz/products/c ... nding-tool
(okay, something in AUS for $28,80) :
https://www.henchman.com.au/PTR30L/Pier ... 0mm/pd.php
(another one in AUS (3 in stock!) :
https://www.oritech.com.au/PTR30L/Pierg ... ier/pd.php
- dragonbat13
I hope it's okay to hijack this thread. Seems the OP found something in Australia.
I'm looking for something available in the USA. But I have a few questions.
I found a pair that had the kink forming part, but the jaws were bent at a 45 degree angle. I assume that would be to avoid cutting the lead, which is a feature I want.
Does anybody know of a source in the states for this tool?
EDIT: apparently I can get them here:
https://www.techni-tool.com/product/HAK ... D-PNR-30-D
I don't want to order it without insuring it's does what I want.
Mark Clay
