Cathode resistor and IM distortion
I have some unwanted IM distortion on my hodge podge mess (lite 11b with double power section running 4x 6p1p ) especially when running in pseudo SE mode with an mv on one half of the power section.
I currently have 16v across 220 ohm 5w cathode resistor bypassed with 2200uf cap, shared between each pair of power tubes.
I have 180 ohm 5w resistors handy but only 100ohm 1/4w to try the tail resistor/ unbypassed portion of the cathode resistor. Is 3 of those in parallel after the bypassed 180 ohm a hodge podge bodge too far? Just to try out it out.
Re: Cathode resistor and IM distortion
That's a unbelievable huge bypass cap if it's not a misprint?
Apparently they are common on 18 watt marshall style circuits.
The 18w guys' theory is giant cathode bypass cap = closer feel to fixed bias. Haven't poked around the 18w sites in a while, but 1000uf used to be pretty common, I guess the value has inflated. I have played around with 470-1000uf, sometimes I think I notice a difference in feel with giant caps, and sometimes I can barely tell the difference between no cap and a 47uf. No idea why.
WhopperPlate
Some days it’s hard to finger a barre chord . Other days it’s hard to make any mistake. We are human .maxkracht wrote: ↑Mon Feb 12, 2024 5:23 pm The 18w guys' theory is giant cathode bypass cap = closer feel to fixed bias. Haven't poked around the 18w sites in a while, but 1000uf used to be pretty common, I guess the value has inflated. I have played around with 470-1000uf, sometimes I think I notice a difference in feel with giant caps, and sometimes I can barely tell the difference between no cap and a 47uf. No idea why.
Charlie
I am the first to assume my own incompetence or tiredness above anything else, but I have noticed this on multiple occasions where a bypass cap just doesn't do much of anything or a very big bypass cap isn't different from a normal-sized one. Triple checked wiring, and confirmed by client asking what the hell does that switch do, i can't hear any difference. Has happened most when rebuilding old projector amps, so maybe it's due to poor low frequency response in the OT.WhopperPlate wrote: ↑Mon Feb 12, 2024 6:00 pm maxkracht wrote: ↑Mon Feb 12, 2024 11:23 am
I think those resistors would let you know before anything bad happened. Could also run resistors for each tube, before the shared 180r, to get some extra feedback going.
Yes sorry I was going to run the extra resistors from each tube to the shared resistor on the board. Do I need to double the value of the non shared part of the resistance? Ie going from a shared 220 ohm to a shared 150 ohm I need to make up 70 ohms equivalent shared resistance. Am I looking for 70 or 35 or 140 ohm for the individual cathode resistors?
I think you would want 140R if using one for each pair of tubes. Total is in parallel. So 280R if using one per tube?
I'm really confused now. Currently each pair has 220ohm shared resistor bypassed with 2200uf as stated.
Case 1.Say I change that to 180 ohm bypassed plus 40ohm still shared then I've changed nothing except the bypassed portion of the cathode resistor.
Case 2. If I make the non bypassed part individual to each tube then I need to double it so; 180 ohm bypassed and shared plus 80 ohm individual to each tube. Am I correct?
Is there an advantage to case 2, ie extra localised feedback or is it just extra faff?
Sorry, I misread. Thought you had one single, shared, cathode resistor and were changing to 2 or 4.
Benefits for option 2: potentially allows a bit more mismatch between each tube and you are spreading the resistors' heat out a bit more if you're using something underrated for the job. Probably not a significant difference and no idea if there are any other benefits, haven't tried.
I've never heard of a pseudo SE mode. How exactly are you doing this? I would imagine some weirdness if half of the output isn't working.
I called it pseudo SE, it's in a KOC book apparently, but its basically a mv for one side out of the phase inverter grounding the signal to 2 out of 4 tubes with a pot. I got it from the vajra schematic (pp-se mod) on 18watt.com there are various versions of it. I like it a lot except for excessive IM distortion. But I'd like less IM distortion when the amp is running all 4 tube normally too...
Weird, I would have assumed the OT would do some weird stuff with that setup...
Have you tried this?
https://www.18watt.com/storage/18-watte ... fo_311.pdf
Yeah I thought so to but couldn't find any negative reports. I have the Paul ruby mod installed.
