My next project is building a Deliverance (60) clone with a JCA50 Chassis and Transformers.. I've really flip flopped on the Power Tubes I'll use given the original iron was meant for 6L6's.. A big part of that sound is the authority a KT88 can deliver. I figured a KT66 would be close and a good match for my OT.
However, a respected member on another Forum stated that the lower Impedance of a KT88 would not be a problem and that I should bias 70% for a 30 watt Tube, thereby limiting the current demand on the OT. This sounds reasonable to me. He also recommended using 100K Grid Resistors for Bias vs 220K. Even the JJ Data Sheet recommends this. https://frank.pocnet.net/sheets/163/k/KT88.pdf
I can supplement the Heater Current with this little guy feeding the 5-Preamps and use the stock PT for the Power Tubes. https://www.mouser.com/ProductDetail/Ha ... eTYw%3D%3D
All knowledge and experience welcome!
