I recently learned that the early 1970s Ampeg V3 and the B25 were very similar amps. The story is that the V3 was modified/voiced for guitar (the B25 was a bass amp).
I looked at the schematics to see the differences and I'd like to learn more about them, specifically the output/phase inverter area as it seems that it has the most significant changes between the two.
* cathode and plate on the V3: 14k + 1k and 15k, respectively (cathode and plate on the B25: 47k)
* control grid resistors on the V3: 47k (on the B25: 100k)
* cathode bypass cap on 12AX7 channel 1 doesn't exist on the V3
* no NFB on the V3
* 3M9 missing from PI in V3
There are other differences in the power supply but I don't suspect that they contribute significantly in the difference in tone between the two.
I was wondering if I were to convert my B25 head to a V3 if it would then "lose the magic" when used with bass guitar? It is a nice round tone when playing bass through it.
Thoughts?
