5E3 DC on .02 PI coupling cap?
angelodp
Post by angelodp »
Hi, have a narrow panel 5E3 amp that is passing DC on the .02 coupling cap to the PI. Have swapped in a new cap and still have DC? Have swapped 12ax7 tubes no help. All the resistors around that circuit are in spec. Not sure how that DC is getting through that cap? Any guidance appreciated.
A
sluckey
Re: 5E3 DC on .02 PI coupling cap?
Post by sluckey »
angelodp wrote: Fri Jun 16, 2023 11:59 pm Hi, have a narrow panel 5E3 amp that is passing DC on the .02 coupling cap to the PI. Have swapped in a new cap and still have DC? Have swapped 12ax7 tubes no help. All the resistors around that circuit are in spec. Not sure how that DC is getting through that cap? Any guidance appreciated.
That dcv is not coming through the coupling cap. It's coming through that 1M connected to the cathode circuit.
Don't worry. It's all good.
angelodp
Post by angelodp »
Thank you sir.
A
angelodp
Post by angelodp »
Steve, on this same 5E3, it plays nicely, but when you remove the guitar cable and crank the volume it goes into a screechy oscillation, that goes away once a guitar cable is added to the amp?
A
sluckey
Post by sluckey »
Most likely a wiring error on the input jacks.
angelodp
Post by angelodp »
Looking through it with a fine tooth comb.
angelodp
Post by angelodp »
Input jacks are correctly wired. The amp (when no cable is connected), if you crank up the two volumes, will go into a screechy oscillation. I have looked at lead dress and checked for DC leakage. Limiter shows no shorts. The amp has been re-capped throughout by a fellow at Div 13 some years ago. Rob R has a voltage chart, I'll post where I am at with current voltage levels and some pics.
LOUDthud
Post by LOUDthud »
Check that those input jacks ground the signal when they are supposed to.
sluckey
Post by sluckey »
Show us your schematic if different from the stock 5E3. Also some high rez pics that show your 4 input jacks wired to the 12AY7 could be helpful.
With nothing plugged into any of the four input jacks, you should measure about 34K between pin 2 and chassis and pin 7 and chassis. What are your actual readings?
angelodp
Post by angelodp »
Crud on the Jacks. So it was the jacks, although they are correctly wired, there had developed a cold solder. I rebuilt the jacks and its working correctly. Thanks for the support and intel.
Best A
angelodp
Post by angelodp »
the Amp.... now Stone Quiet and sounds damn good
