I recently finished a Tweed Twin 5f8A build. I am very pleased with it. However, I noticed that when the bright volume is maxed out along with the normal volume, I get a 60 cycle hum. I think this is because the low jacks are not grounded to the switch (ring), so all signal is allowed to be picked up by the low jacks. You can see in the photo below that the ground terminal of the low jacks remains unused. If it were connected to the switch, all signal picked up would bleed to ground. Of course to do this you would have to sever the tie between the high and low jacks.
My question is:
Why are the tips of the high jacks connected to the switches of the low jacks?
Wouldn't it make more sense to not connect the jacks in this manner, and instead connect the switch of the low jack to ground (just like the high jacks) so that it does not act as an antenna and create hum when both volumes are turned up?
Thanks for your input!
Picture of the finished build:
https://photos.app.goo.gl/wMoH2Km6CiseexNi7
