yes, these are big, being perfect for 150w SSSs too
Bass Amp for a friend
Re: Bass Amp for a friend
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Based on the tests I've done, to me and my friends UL with guitar needs to be lower and then a bit of gnfb just for presence, because the amp needs to lower its Rout at higher frequencies and "feel" the impedance of the cone there, or it will be too tight and a bit dull. The other good aspect of playing with UL and loadlines without gnfb is that you can tailor the compression at higher volumes by playing with the shape of the curves and the loadlines. I was indeed expecting something in the range of 12kg, because I imagined something like the Hammond 1650W.
