So my replacement transformer is back in my chassis and everything is looking good so thanks everyone for confirming that the transformer was at fault not me!
On a side note,
During the transformer saga I ended up with a spare power transformer with a 100-120-230-240V primary.
Would it be feasible to use this as an auto transformer to give me a lower supply voltage (I'm in the UK on 240V) to feed my PT for the initial amp power up when I get that far?
I'd still be using the light bulb limiter of course.
Craig
									Power Transformer - Am I Doing Something Stupid?
Re: Power Transformer - Am I Doing Something Stupid?
Thinking about my second build.
Yes, you'd basically have half voltage available, which would let you bring your capacitors up to working voltage in two steps.
Thanks Martin,martin manning wrote: ↑Tue Sep 07, 2021 1:59 pm Yes, you'd basically have half voltage available, which would let you bring your capacitors up to working voltage in two steps.
That's what I was thinking but will I actually get any B+ with only half voltage on my rectifier heater?
If not could I leave the rectifier tube out and bridge it with a couple of diodes?
Craig
I think you will get something with half voltage on the rectifier filament. Maybe add silicon diodes as the next step?
Thanks Martin,
I can get back on with build now.
While I was waiting for the new transformer, Sod's law struck and my trusty old soldering iron died on me!
Craig
Craig
				thetragichero
it's so nice to see a manufacturer (even in a niche industry such as ours) stand behind their product like that. i'm glad you got it sorted!
