Missmatched 6550s - adding additional bias for each set.
beedoola
Post by beedoola »
I have a Ampeg v4 that was converted to run 6550s. Someone put one bias resistor on Pin 8 of one of the power tube sockets. I decided to add three more to check the bias of the other 3 tubes.
When I got the amp, it only have two 6550s - the guy was running it at half power - so I ordered two more. Thing is now the other two are biased at 42ma and the inner two at 24ma.
Is there anything I can do to get them biasing close to one another?
UPDATE: I'm thinking of adding an additional bias control so I can have each pair biased to get a total equal amount.
The bias circuit in my amp more closely resembles this schematic:
https://www.ampegv4.com/images/schematics/V4B.jpg
Can I remove R60 and C23 to make it more like the bias on this version?
https://www.ampegv4.com/images/schematics/V4.jpg
And then remove the connection to R36 and R35. Running a bias pot to each of the control grids. One bias control would go to the control grid for V5/6and the other for V7/8.
Or do I need to built another bias supply and connect each at rectifier bridge and split them from there to each set of tubes?
roberto
Re: Missmatched 6550s
Post by roberto »
Install four separate pots to individually bias each tube.
Dedicated coupling caps are needed for each tube as well.
Post by Stevem »
If I recall right the v4 has some 540 volts on pin 3 of each of the outputs so pulling .042 amps is very close to the hot biased limit of 70% dissipation.
I would change the main bias resistor after the diode to a tad smaller value and get those two hot tubes down to 39 or 40 ma and then just live with the other 2 tubes running cooler. Just make sure to have one of each tube on each side of the OT secondary winding.
I bet even set up like this that monster will still output 80 watts of loud clean power for a good amount of time which will let you save up for new tubes,which by the way since JJ makes 7027s now you can go back to the original outputs that amp and its bias circuit where made for !
beedoola
Re: Missmatched 6550s - adding additional bias for each set.
Post by beedoola »
I added a question/changed the title to reflect the question. Thanks for the replies so far.
I forgot to add I also already have one bias control - a resistor in series with pot - in place of R49
roberto
Post by roberto »
Hi beedoola,
good practice is to go on with the conversation.
If you edit the original post many times, everytime it is needed to re-read everything from the beginning to understand what you have changed, and the whole sense of the replies is lost.
Post by Stevem »
If your looking to have a separate bias adjustment for each tube, London amps has a nice kit that does not hurt the walet!
Post by Stevem »
If your looking to have a separate bias adjustment for each tube, London power has a nice kit that does not hurt the walet!
roberto
Post by roberto »
chaccmgr
Post by chaccmgr »
I had a similar problem in an amp and I made a small pcb with 4 trimmers to individually bias each tube. It is a bit fiddly to dial in the values for all 4 when the main bias pot is still in place, but finally worked
got some PCBs left here in Germany
beedoola
Post by beedoola »
I'm thinking of leaving the stock bias, as shown here below. Cutting the trace that goes to the Grids, making the stock bias supply V5/6.
Then making another of this bias circuit on a perf board. Tying into the diode bridge and ground, and then the output going to V7/8. A trimmer for each side - taking the place of R49. Will that work?
