What does the v3 tube do in this schematic? Thanks
v1b is OD channel
v1a, v2 is clean channel
v3 ?
What does V3 do in this?
- pompeiisneaks
- Site Admin
Re: What does V3 do in this?
thank you - just phase or is there some gain there also?
- pompeiisneaks
- Site Admin
The phase inverter splits the input signal into an inverted and a normal signal to send the signal to each side of the Push Pull output pair in a push pull amplifier. Read this to understand more:
http://valvewizard.co.uk/
there are 4 different articles on the left side about different kinds of phase inverters and what they do.
also https://robrobinette.com/How_Amps_Work. ... _Tail_Pair is a generally great overview of a lot of how one specific kind of phase inverter works.
