'60s Brown fender vibrato builds ?
shuie
Post by shuie »
Has anyone ever built and documented an amp that used a harmonic vibrato similar to the Brown '60s Fender Concert, Pro, or Super? Is this tremelo even feasible in one of the 18watt amps, or would it be better to just use a Univibe or some other kind of pedal?
TIA
benoit
Re: '60s Brown fender vibrato builds ?
Post by benoit »
There's just such a schem over at 18watt.com. If I'm not mistaken the original marshall had trem built in. In any case the 18watt guys should be able to help.
leaveitalone84
Post by leaveitalone84 »
The TMB channel of the marshall 18watt builds were originally tremolos.
shuie
Post by shuie »
I posted something specific to the 18watt amps over there. I didnt mean to restrict this discussion to the 18watt stuff here. In general, would it be reasonable to build a Brown '60s Fender harmonic vibrato tremelo type of circuit into say a Marshall, Matchless, etc., flavored clone? Or, is it easier just to get that effect out of a pedal?
statorvane
Post by statorvane »
I have added a tremolo to a SE amp. The parts count was trivial, and only used 1/2 of a 12AX7. However, IMHO it is not as flexible as a pedal trem unit. Mine homebrew has a depth and speed adjustment, similar to Fender type controls. However there is no waveform variation feature as on some advanced pedals. Doubt you would like it in favor of a Univibe assuming you are after R.Trower sounds. I still like the internal one I built. I added a footswicth to toggle it on/off.
If you are adding one to a Marshall type amp, may want to check the BB files at the JTM45 discussion on Yahoo groups. One version (BB45 I think) had a tremolo.
