No 5v tap on 100w PT
Re: No 5v tap on 100w PT
Post by Stevem »
Most modern amps but for dam Mesa in regards to the bias pot!
studiodunn
Post by studiodunn »
sluckey wrote: Sat Feb 22, 2020 3:06 am I wonder what Leo would say. :D
Use what we have :D
studiodunn
Sidebar question:
The PT shows the 6.3v CT internally grounded. I assume that means tape it off and bury it?
I would ground it with the HV CT. Otherwise you would be relying on the mounting bolts to ground the filament CT.
studiodunn
martin manning wrote: Wed Feb 26, 2020 1:47 am I would ground it with the HV CT. Otherwise you would be relying on the mounting bolts to ground the filament CT.
Thanks Martin. So internally grounded is just referring to the chassis of the transformer.
Yes, that's correct.
