1987 clone mods.
Smokebreak
Re: 1987 clone mods.
That's a neat mod Roberto. Do you find the bypass-limiting resistor works for all volume levels, once set to the user's liking?
Not exactly. That's why I wrote to test the resistor at different volumes.
You have to find a compromise at the volume you are more used to play.
Of course the LARMAR can be switched in/out to obtain two different volumes.
Thanks so much for all the responses!!!
I'm comfortable with the relay setup and install to switch the pots. I'm just looking for the best way to achieve that and keep the tone I have.
This whole idea comes from a Plexi RI that John Suhr modded for me some 15 years ago. It has a PPIMV and two separate Volumes that I can footswitch between. The sweet thing about the switchable volumes is that I can bump my volume mid song for solos without any tone change.
I'm going to open my plexi and look a little closer at what John did around the two volumes. Then maybe I can come back with questions that are more to the point.
It's too late for that! Although my tech knowledge is too light for a build for sure.Tone Lover wrote: PS. it might save you from this horrible addiction called amp building once you smell the smoke your lost.<G>
Actually, I thought combining the channels might be cool, but since I like the tone I have, I've re-thunk it and think it's prudent to not combine the channelsJoeCon wrote:Guys
Sounds like he wants to control both channels with one pot, so wouldn't a dual pot work here? Come off the bright and normal coulpling caps to a dual pot...
How to use the second volume for a "foot switchable volume" I don't get...
So far, every boost (clean boost, OD, etc) I've tried changes the tone. It seems that anything changing the level hitting amp changes the tone some. Whereas the Suhr mod above works like I went and twisted the volume knob.Tone Lover wrote:Leave them stock and boost the front end with a clean boost for your solo. I know its not the answer you want.
Scott
RockinRocket
When playing through the bright channel and having the normal channels pot on zero. The resistance is 470k to ground correct?Smokebreak wrote:
Looking at the schematic, you'l see that depending on where the unused pot is in it's rotation, you can get anywhere from 470K to 1470K to ground.
Smokebreak
Yep, that's why you just see 470K on a lot of single channel plexi type amps.
