Hey guys,
I'm using a LAR-MAR style PPI master volume on a circuit similar to an AB763. Started wondering, though.... revering to the diagram attached, the note says "to pins 5" of the output tubes. Does that assume on a standard AB763 you would connect this like the normal PI output, to the 1.5k resistor on pin 5 of the power tube, or are is this saying to remove the 1.5k?
Humbly,
Mark.
LAR-MAR pre phase inverter question
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
@MalinAmps
Re: LAR-MAR pre phase inverter question
You want to keep the grid resistors.
Thanks - I thought soxtian wrote:You want to keep the grid resistors.
Mark.
@MalinAmps
@MalinAmps
