What should I build around this OT? (Triad S-149A)
MHProd
Post by MHProd »
Seems to be from the 70s. 3K3 Primary.
I'm thinking a Plexi 1986 (bass circuit, shared cathode) with paper in wax caps for a different flavor.
What do you guys think?
ToneMerc
Re: What should I build around this OT? (Triad S-149A)
Post by ToneMerc »
Would be a shame to waste the UL taps, how about a RT 66, run it at 6.6K, with 8, 16 and 32 taps?
TM
MHProd
Post by MHProd »
Hmmm, maybe.
What else?
Post by Stevem »
If its interleaved wound ya might want to go with oil type caps !
sluckey
Post by sluckey »
Sunn
I think you are in the sweet spot at 3.3K for a pair of EL34 @ ~400V.
matt h
Post by matt h »
(deleted)
rp
Post by rp »
That's high quality iron, if you had a pair some DIY hifi guy would get all wet over them.
You never know with untried iron but looking at the entrails the auspices are good for a Plexi, maybe very good. My only worry is that it's 50W 20-20K. Maybe too clean and tight? Maybe a 525V Plexi? Maybe one of those KT88 Parks? Maybe 4 X KT66 JTM45 super lead? The tube gods bless madness.
If the entrails prove wrong you can always just swap a Marstran etc.
Let us know.
MHProd
Post by MHProd »
Thinking about a pair of KT88 with something around 420V B+
Don't mind clean as long as it's not too tight.
matt h wrote:I'd rather double up and use it as a 6.6k-er... I'm crazy and no one likes me. Ignore this.
That's what I heard sounds good from a very good ear . keep the b+ low under 400.
MHProd
Post by MHProd »
Hmmm, I didn't consider using it as a 6K6... I'm about to start an Express build. I might try the Triad...
gingertube
Post by gingertube »
OR
A quad of EL84, Vox AC30'ish
OR
A quad of 6V6 for a "mini" Bassman.
Either of these 2 options will give you around 30 Watts and both sound great.
Ian
