Stand alone preamp output wiring
Mat Cortex
Post by Mat Cortex »
Hi TAG member,
i'm fairly new to amp building and i'm currently building a stand alone preamp wich use this jensen output stage (line level). since Jensen OT are way overpriced, EDCOR recommend the XSM10K-600 as a replacement.
But i've no idea how to wire the output of this thing !
Wich pin should i consider as the ground ?
Is Output (+) ans Output (-) the signal for a stereo jack and center tap, the ground ?
Do you think i should always put a resitive load on the OT when powering the preamp ?
Mat
1965 Gibson Falcon GA19-RVT
Re: Stand alone preamp output wiring
I think you can ignore the center taps on the Edcor (use pins 1 and 4, and 5 and 8) and connect it as shown in the Jensen diagram. On the primary, pin 1 is the signal, and 4 is ground. The secondary is shown assuming it will be feeding an input that has its own ground reference.
Don't forget to add ground lift switch you will most likely need it.
Mat Cortex
M Fowler wrote:Don't forget to add ground lift switch you will most likely need it.
On the output jack only ? ( see attached)
On the xlr balance line out.
Mat Cortex
Thanks M Fowler
