I don't post a lot, but when I do, it's to this board.
Anyways, I took advantage of the cheap Judybox amps from a while back, and surprisingly, mine was in 'okay' condition (same crappy soldering, wire all over, etc.). It did work out of the box and sounded nice, but I thought it was a bit bright in one of the channels. Long story short, I pulled all of the board components and rebuilt/rewired everything (so stock layout/values, just rewired and cleaned up) and found a missed connection. So, all is well.
But, I can't leave it well enough alone: I have to tinker. What I'd like to do is make it so it can be 6L6/KT66/EL34 drop in compatible (has 6l6GC now) and maybe move it to Class A (or AB, or whatever).. So, here's what I have voltage-wise for now:
B+1: 346 (feeds OT B+ and plates)
B+2: 329 (feeds screens -- pin 4)
B+3: 241 (feeds preamp and PI)
Currently, it is cathode bias (which I'd like to leave) with 250 ohm resistors on each tube. That makes the bias a bit hot according to Weber's bias calculator (about 80%). Yep, I need to change the cathode resistors. What I'm thinking is put a 250 ohm resistor attached to the cathode then a 500 ohm rheostat attached to the 250 ohm resistor going to ground. Adjustable cathode bias for each tube. Feasible? Or am I just crazy? Oh yeah, OT can be 8k or 4k, depending on secondary (16/8/4 for 8k and 8/4/2 for 4k)
Is there anything interesting that could be done? I like the sound, I just want to open it for some flexibility and have fun and learn about the changes. Shoot me some ideas. I can draw up a sketch of the schematic, get other voltages (what they are now), or get pictures. Throw me some ideas, help me have some fun and make this amp really interesting.
Patrick
PS: I probably won't make clips because (a) I don't have mics and (b) I am a terrible guitar player.
