Good Radial Power Supply Caps?
wattsup
Post by wattsup »
Are there good brands for radial power supply caps? If there are what should I look for that makes good caps for a power supply?
Re: Good Radial Power Supply Caps?
I order radials from mouser and newark. Nichicon and Panasonic are good and inexpensive.
ToneMerc
Post by ToneMerc »
wattsup wrote:Are there good brands for radial power supply caps? If there are what should I look for that makes good caps for a power supply?
https://tubeamparchive.com/viewtopic.php?t=10056
TM
wattsup
Post by wattsup »
Thanks guys. Other than voltage, is there anything specific to look for?
John_P_WI
Post by John_P_WI »
wattsup wrote:Thanks guys. Other than voltage, is there anything specific to look for?
105C temp rating and 10,000 hour life
Post by Stevem »
The F & T brand has been good so far and a good dollar value also!
Ken Moon
Post by Ken Moon »
Take a look at the Nichicon PW series.
This is a very nice, long-life cap that is readily available.
http://www.nichicon.co.jp/english/produ ... s/e-pw.pdf
The VZ series is a very popular cap, just not quite as expensive as the PWs, and a hair smaller in most values.
You can go to 450 volts with these, at up to 100uF. The 47uF/450V PW is great for filter caps in a guitar amp.
F&T is great also, as are the BC components caps that are popular in the UK from Farnell, but Newark carries them, as do Mouser and Digi-Key in some values/sizes.
wattsup
Post by wattsup »
Oh thanks I think that's what I'm wanting to know! You guys rock!! :D
