See attached schematic.
Im not sure how the tremolo actually functions in this amp. Is it feeding an oscillation into pin 9 of the power tube? I see that the v4a has its grid connected to its plate, so im assuming its just sending some kind of oscillation into the power tube?
Can someone explain how this tremolo works?
beasleybodyshop
vibratoking
Re: Can someone explain how this tremolo works?
V4a is an oscillator and the cathode of V1a is sharing the cathode of V4a. So the voltage on both cathodes is oscillating. V1a is a gain stage with it's bias varying due to that connection.
Although not the exact circuit you posted, this link should help:
http://www.valvewizard.co.uk/trem1.html
Over simplified, but essentially (guessing)...
The plate of the oscillator tube (V4A) is connected to 3 R/C "filters" each of which has a time constant that is affected somewhat by the pot. These things suck voltage from the circuit and then stop for a short interval and then do it again. This affects the B+ rail to the preamp. You can hear this.
I'm guessing. Put a meter on the B+ node at R10 where the trem circuit connects. Turn on the tremolo. See if the voltage wiggles. Let me know what you find out!
Vibratoking has it spot on!
Cheers
Shane
Cheers
Shane
Here's another take on preamp cathode wiggling.This one spounds pretty good
beasleybodyshop
Thanks guys, I got one of these here Kalamazoo Model II's on my bench and was curious as to how it only worked with half a tube.
Wiggle trem sounds alright. It fits for this little amp perfectly well.
beasleybodyshop
Wait a second....doesn't electron flow occur from cathode to plate? Why would the voltage wiggle if the oscillator is after the cathode?
- gui_tarzan
It would still start and stop in a complete circuit.
--Jim
Smokebreak
Funny , I just finished putting this Supro circuit in an old Bogen. Very similar preamp wiggle. I was a bit hesitant to install the intensity pot!
I don't mean to hijack, but since we're talking preamp wiggle, I have a question as well :
I built this up w/o trem first, and when I added the trem, I expected the sound/gain to change in the cathode biased input channel, but it didn't(I don't think). The oscillator and preamp cathodes are separated by the 15K and "on" just shorts cathode>cathode, same with the footswitch
So how does the preamp's bias not change even with the trem "off"? 15K?
