Suitable 5AR4 for Vox AC-30?
Post by Mark »
I have to put a rectifier tube into an AC-30 and I'm curious as to which brand of 5AR4 or gz-34 have you guys found to be robust enough to handle the AC-30?
I would like to stipulate only new production valves, the NOS option is too expense to consider.
Thanks for your help.
Yours Sincerely
Mark Abbott
oldhousescott
Re: Suitable 5AR4 for Vox AC-30?
Post by oldhousescott »
Well, I've had both JJ and Sovtek go south on me (in a Deluxe Reverb), so I think it's a crap shoot with current production tubes. That said, if size is an issue, the Sovtek is smaller. Otherwise, I believe the JJ follows the original performance curves a little better. Don't know anything about the Chinese versions.
"We put a little quality in everything we build..."
jelle
Post by jelle »
I have had luck with a chinese GZ34 in my superreverb. Great sounding....I tested several batches sovtek's ( I did not like these at all) and this chinese tube held up tonewise against a NOS Philips Miniwatt GZ34. :wink:
I assume it is a Sino but I'm not sure.
Jelle
