Bogen CHB-50 and suggested proceedings
beedoola
Re: Bogen CHB-50 and suggested proceedings
Post by beedoola »
Markusv wrote:For my suggestion, the one half of the 6EU7at the input:
Typically /traditionally there is a 100K resistor connected to the plate of the tube. Then there is a parallel 1.5K resistor/22uf capacitor between cathode and ground.
It will drive the following stage a bit harder for better breakup etc
Please look at typical Fender schematics like say a Bassman or a Deluxe Reverb etc for comparison.
The suggested 33K or 68K grid stopper on the 6EU7 grid is to block unwanted frequencies like radio stations and the like
Markus
Disclaimer- I'm no tech wizard so my explanation may be clumsy
Did you remove the .01 from the plate, and just have the 100k and 150 cap in parallel?
and the 1.5k/22uf on Pin 9 (the cathode) was only done to V1A, right?
I added the schematic with the highlighted part.
The 6EU7 is grid leak bias.
beedoola
Post by beedoola »
So I did the mods Markusv and M Flower suggested: Thanks to you both.
Amp sounds pretty good. Another guy had sent me his augmented CHB-100 schematic and one of his mods was to move the Master volume to right after the 12AX7 stage and before the 6C4. I tried it and it produces lots of gain! very grainy. Cool sound but I'm not sure if I like it.
The amp sounds great right now but I'd like to try and get more gain out of it. Besides cranking it or using a pedal, what might be some other options?
