Replacement amp handle
beedoola
Post by beedoola »
I need a handle for this amp - Guyatone GA-2000 MKII but I'm not sure what kind to get/if it will be compatible. Does anyone know what would work for this amp?
The imprint on the tolex shows it has the end cap/fasteners that have to holes. Seems like the nut is attached/jammed into the wood on the underside of the cabinet. Looks like the total length - judging by the tolex imprint, from one tip of the mount to the other is around 10 5/8"
Here is a pic of a different model but I think the same amp pretty much...
[img:409:336]http://www.jedistar.com/images/amp/guyatone_amp.jpg[/img]
Re: Replacement amp handle
