Oddball Preamp Circuit?
jbefumo
Post by jbefumo »
I stumbled upon this schematic for the Allen Class Act amp, and am intrigued by the post-volume-control preamp stage, which appears to be combining common cathode and cathode-follower signals from a single tube (see attached.) First of all, is there a name for this? I'd like to learn more about it, so knowing the proper term would be a big help. I tried prototyping it and it seems to sound good. Examining the output in Multisim, it also looks as if the two signals are slightly out of phase, and I'm wondering if this is an intrinsic aspect of the design, or an incidental effect.
Thanks.
Joe
Re: Oddball Preamp Circuit?
Looking for the layout of this amp.
10thTx
Post by 10thTx »
I am not seeing a cathode follower there?
Maybe I am missing something. Looks like a common voltage divider that is grounded "above" the cathode resistor of the previous gain stage. And then negative feedback off a cathode in that last gain stage.
With respect, 10thtx
surfsup
Post by surfsup »
10thTx wrote:I am not seeing a cathode follower there?
Either am I. Considering there are two versions of this schematic floating around, the circuit looks to be shunting bass frequencies with a knee at 35Hz (or 159Hz for the other version) back to the cathode of the stage (which is inverted from the plate) to reduce bass frequency output as local feedback, as well as a functioning voltage divider going into the grid of the next stage.
jbefumo
Post by jbefumo »
Sorry - wrong terminology - I was just referring to the signal being taken off of the cathode and mixed with the plate output through those two 470k resistors. Is there a proper name for that topology?
[quote="10thTx"][quote]combining common cathode and cathode-follower signals from a single tube [/quote]
With respect, 10thtx[/quote]
jbefumo
Post by jbefumo »
Oh - wait -- is that a feedback TO the cathode? This is definitely skirting the fringes of my current theoretical limitations.
jbefumo
Post by jbefumo »
Perhaps a more succinct question would be: What is the purpose/effect of connecting the cathode to the output of the stage as shown?
Yes, there is a bit of negative FB on V1a, but it's so small it will have virtually no effect on the gain or frequency response of that stage. The only significant thing I see happening is that V2b's grid is elevated to V1a's cathode potential (~3V), which is going to make V2b's bias pretty cold.
jbefumo
Post by jbefumo »
Hmm, so the connection of pin 3 of V2, via the 470k resistor, to the grid (pin 7) of V2 is solely to raise the bias of that stage?
When I put a scope on pins 1 and 3 of V2, I see a signal at the cathode, smaller than that at the plate, and almost, but not quite 180 degrees out of phase. My initial impression was that the two signals were being combined at pin 7 (grid) of the next stage. My sense was that this would reduce the overall level of the signal. Is this not what's happening?
Andy Le Blanc
Post by Andy Le Blanc »
its adapting a high gain pre to SE power side, picture the coupling cap going to the cathode, what happens?
Then add the voltage divider to the next stage.
lazymaryamps
Firestorm
Post by Firestorm »
To me, it looks like the output of V2a is mostly being voltage-divided in half (with a little feedback, too). Similar to V1b where at least half the output is attenuated (with the volume up full). That's a lot of gain stages in front of the tone stack. If you don't dump some of the signal, it would be an unmanageable monster.
jbefumo
Post by jbefumo »
Okay, I see now -- thanks! (Have to confess that I had to simulate what you described in Multisim to grok it.)
[quote="Andy Le Blanc"]its adapting a high gain pre to SE power side, picture the coupling cap going to the cathode, what happens?
Then add the voltage divider to the next stage.[/quote]
VacuumVoodoo
Post by VacuumVoodoo »
This amp schematic is nothing more then Sovtek MIG-50 preamp into a SE output. As for that 3rd and 4th stage duo. Clue: some people say those MIgs have cool overdrive and distortion.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
jbefumo
Post by jbefumo »
I never checked those out - thanks.
I wired this up with a 3PDT switch to defeat that loop, and really like the result. Engaging it cleans things up, reduces gain, and makes the whole thing more articulate.
jbefumo
Post by jbefumo »
So ... is there a NAME for that circuit topology?
[quote="VacuumVoodoo"]This amp schematic is nothing more then Sovtek MIG-50 preamp into a SE output. As for that 3rd and 4th stage duo. Clue: some people say those MIgs have cool overdrive and distortion.[/quote]
