Shock mount preamp tube sockets?
David Root
Post by David Root »
As a means of pre-empting microphonics in both preamp and power tubes, these have occasionally been used in MI amps, eg the Gibson GA-6.
Anyone have any experience to offer, particularly in adding it to an existing chassis mount socket? Rubber grommets around the mounting screws, for example?
Rattlecat
Re: Shock mount preamp tube sockets?
Post by Rattlecat »
Not sure how I came across this site, but it is relevant to your topic.
http://members.aol.com/sbench101/#Microphonics
Zippy
Post by Zippy »
Grommets will CHANGE the resonant frequency of the vibrations but not eliminate them. You might play with o-rings of varying durometer.
David Root
Rattlecat, thanx, I'm sure that would work, but it's way too ugly!
Zippy, you're right, you don't want the sockets jumping around. O-rings might do it OK.
Following on that thought, how about collar washers, one or two, fiber, nylon. Maybe not shock resistant enough?
