small vs large fuses ??
I found a neat little AC power receptacle with built-in fuse drawer. The fuse size is 20mm x 5mm...Quite a bit smaller than the size of fuse you'd find in a blackface Fender, for example.
Are these small fuses just as good/reliable/robust as the large ones?
- Milkmansound
Re: small vs large fuses ??
just make sure you can find a slo-blo in that size. Shouldn't be a problem
I find the 20mm fuses cost more!
i was just at radio shack. they have slo and fast fuses of all different values needed in that size.
I was looking online at Mouser, and those fuses costs around $7. I couldn't believe they are so expensive!Phil_S wrote:I find the 20mm fuses cost more!
hoffman has them $1 a piece
guitarmike2107
20mm x 5mm is used in the uk all the time, sorry that doesnt help those on the state side.
Mike
Mike
Same in Aust. Standard fair and in all of my amps.
20x5mm are often referred to as Euro size, and the 1-1/4" as being US size....
diagrammatiks
radioshack and home depot have littelfuses they are less then a dollar, usually 4 for 2 or 3.
pretty common things now a days.
