Trainwreck endbells
Trainwreck endbells
I got a couple of sets of Power and Output transformers for a couple of Trainwreck Liverpool builds that I received with the endbell dented (all 4). Anyways I took one of the endbells off and tried straightening it as best as possible and then I sprayed it with black wrinkle finish paint. Not bad but I thought since I have a machine shop why not machine full endbells that encapsulate the transformer. So I've attached a couple of pdf's showing my initial design. The material is 6061T6 aluminum and I will probably anodize it black. I will have a teflon insert where the wires pass through to insure not damage and have a viton gasket where the 2 halves meet to insure a sealed unit. Any thoughts?
Re: Trainwreck endbells
Thoughts:
A) You have a lot of time on your hands.
B) I really want a machine shop. Haard.
Yes to A and B was what gave me A.xtian wrote:Thoughts:
Make sure it's not actually touching the lam stack because you don't want to end up with shorted laminations and a very hot and inefficient transformer.jcsb wrote:Any thoughts?
Don't end bells have to be made of ferrous material to function as effective shields?
No as long as there is some other internal shield. I have a couple of options here. One would be to use one of the shielding paints internally or two there are several shielding films.martin manning wrote:Don't end bells have to be made of ferrous material to function as effective shields?
I admit it would be easier to use a mu metal can, but what's the fun in that?
Yep I thought of that and it has sufficient air gap along with the fact that it is anodized. I did have a thought of potting it too. The last time I did this it turned into a big mess, but worked.paulster wrote:Make sure it's not actually touching the lam stack because you don't want to end up with shorted laminations and a very hot and inefficient transformer.jcsb wrote:Any thoughts?
Hey, I do want to thank those who have asked questions since making this right the first time is what is important.
Thanks,
Thanks,
Those kinds of shields won't keep the magnetic field confined though, will they?jcsb wrote:No as long as there is some other internal shield. I have a couple of options here. One would be to use one of the shielding paints internally or two there are several shielding films.martin manning wrote:Don't end bells have to be made of ferrous material to function as effective shields?
Cool!
Custom Billet Endbells!
Martin I have an old Hammond amp that the PT has aluminum end bells or in this case it's a lay down but the top cover is aluminum that I polished to a high luster so not sure if it has to be ferrous to shield.
Originally Hammond paints them silver.
It does have the copper flux band around the core.
I suppose it would the same as a sheet alumuinum cover for a chassis.
It is designed for blocking EMI & RFI the same as MuMetal, with much higher capacity to absorb. It is a composite that is made of copper/alloy 49/copper material. It is .014" thick and easily fabricated.martin manning wrote:Those kinds of shields won't keep the magnetic field confined though, will they?jcsb wrote:No as long as there is some other internal shield. I have a couple of options here. One would be to use one of the shielding paints internally or two there are several shielding films.martin manning wrote:Don't end bells have to be made of ferrous material to function as effective shields?
