So today I decided to fire the amp up and see if I screwed anything up. Well the lightbulb got bright for a split second and then dimmed to a very soft glow.(SUCCESS!!!!!!!!!!!!!!!!!!!!!!!!) I then took voltage readings and things seemed ok, I then plugged the tubes in took more voltage readings and so far so good. I plugged my guitar in and it sounded great not the slightest bit of hum... very quiet.
I went and ate dinner and decided I would check my voltage readings again and post them here to make sure everything was ok.(Dumb Idea) I was checking my votages at the power tube with the tubes removed and while I was checking voltage at pin 3 my probe slipped off the pin and touched pin 2 at the same time
Here are my voltage readings without tubes and with tubes. I know I screwed something up...but I don't know what. Hopefully I did'nt smoke my PT or OT. Any help you guys can give me would be very appreciated. I'm so pissed at my self right now I could scream.
Voltages...
Mains:120.3 VAC
PT ( I used the 600v taps) 314.2/313.9 VAC
OT (B+) 436 VDC (W/O Tubes) 345 VDC (With Tubes)
B+1 435 VDC (W/O Tubes) 345 VDC (With Tubes)
B+2 435 VDC (W/O) 320.8 VDC (With)
B+3 434 VDC (W/O) 300.2 VDC (With)
V1...
Pin 1- 430 VDC (W/O) 200.2 VDC (With)
Pin 2- 0V (W/O) 0V (With)
Pin 3- 0V (W/O) 1.48 VDC (With)
Pins 4&5- 3.53 VAC (W/O) 3.38 VAC (With)
Pin 6- 430 VDC (W/O) 191 VDC (With)
Pin 7- 0 (W/O) 0 (With)
Pin 8- 0 (W/O) 1.54VDC (With)
Pin 9- 3.54 VAC (W/O) 3.38 VAC (With)
V2...
Pin 1&8- 0V (W/O) .050 VDC (With)
Pin 2- 3.54 VAC (W/O) 3.38VAC (With)
Pin 3- 435 VDC (W/O) 305 VDC (With)
Pin 4- 436 VDC (W/O) 315 VDC (With)
Pin 5- 0V (W/O) .766 VDC (With)
Pin 6- see pin 4 (jumpered)
Pin 7- 3.53 VAC (W/O) 3.38 VAC (With)
Pin 8- see pin 1 (jumpered)
These are all the readings I got. Let me know what you guys think. I appreciate any insight to this.
Thanks so much.
Chuck.
I did some research, and I think I will resolder those two pins and see if that fixes the problem. Man, I hope I did'nt fry my Phillips 7581a
[im[IMG
