MOSFET and zener diode checking on VVR?
rogb
Post by rogb »
Just doing some work on a VVR I have and wondered if any members had some simple checks for mosfets and 12v zener diodes. I had a look around the net but I like to here the views on here :D
selloutrr
Re: MOSFET and zener diode checking on VVR?
Post by selloutrr »
This is as good as any if all you have is a DMM it's not 100% but it's a basic good/bad test. I'm not sure if the test will work if the fet is wired into the circuit.
http://www.utm.edu/staff/leeb/mostest.htm
My Daughter Build Stone Henge
rogb
Post by rogb »
That will do nicely! Thanks! Any good tests for zeners, I have a diode mode on my DMM, assuming they are tested differently from regular diodes?
I tested 2, 1 shows a similar result to a normal diode and 1 seems not to read at all...?
selloutrr
Post by selloutrr »
interesting article. you have to apply voltage while you test zener with a DMM
http://www.elexp.com/t_test.htm
rogb
Post by rogb »
Thanks, I found a similar article, this one is clearer, though :D
After adapting my fixed bias VVR to cathode bias specs...
I did the mosfet test and it seemed fine, and the zener wasn't opencircuit so I temp wired in the VVR and it was fine!
I can turn the B+ right down on the VVR while keeping the OD level up,
overloading the pre amp can be avoided by tweaking down the pre-amp volume.
Result is more feedback at lower volume - great! :D
Now I am fitting the VVR board in the chassis sidewall as per ODS FET board.
I have fitted 1N4007s to divide the power supply but I will swap them out for the faster UF4007 (when I find the buggers :oops: )
Thanks again for taking the time to help out, I had a VVR on my old 5 watter SE scaling the whole amp, power tube only seems ideal on the mini HRM
