1967 AB165 Bassman Head
NickC
Re: 1967 AB165 Bassman Head
Post by NickC »
Have you checked the bias-balance circuit?
I removed the AB-165 style bias-balance circuit on my '66 Blackface Bassman and replaced it with the earlier AA864 blackface era "true bias".
[img]http:2304:1728]http://homepage.mac.com/swamptone/Bassm ... Modded.jpg[/img]
[img:2304:1728]http://homepage.mac.com/swamptone/A-BassmanBoard.JPG[/img]
Some good Bassman info here:
http://acruhl.freeshell.org/mga/main/AA ... AB165.html
Hope that helps.
philo43
Post by philo43 »
Hey guys, I haven't really thought your problem out, but I had a SF Twin that was burning up tubes one-at-a-time and it turned out to be an open ground wire on the board (I can't remember which one). Is the board warped? I haven't seen many older fender fiberboards that stayed flat over the years. You might just re-heat all the eyelets and solve your problem without ever knowing what was truly wrong. Not quite as satisfying as a good troubleshoot but hey...
Tone. It's all in your Head!
ohlingeramps.com
