1/4 A slow blow for HT fuse?
I am building a Fender AB763 type of circuit (two 6L6, 4 triodes).
I want to ad an HT fuse to protect the output tranny. Is 1/4A sufficient (slow blow), or do I need 1/2A (slow blow)?
Re: 1/4 A slow blow for HT fuse?
I'd use a 500mA T fuse for 2 x 6L6s
o.k...here I go exposing my ignorance.
What is a "T" fuse. Is that fast or slow,or something else.
Cliff Schecht
Slow blow I think. I know that fast blow fuses last all of 2 seconds in the HT position. 500mA SB is the guy for most push pull pairs.
Cliff Schecht - Circuit P.I.
Sorry "T" in this instance is an abbreviation for 'time fuse' - i.e.: a slo-blo fuse (even tho' 'time' can be fast or slow depending on how fast you are going)
From my reading around the web, I gathered that an SB on the B+ will be too slow to do any good - ie save the output section. I use FB and with the tube rec amps they hold up well. Occasionally one will will pop using the stanby but it's been rare. FB with SS rec doesn't stand a chance. Please correct if I'm wrong.
- David Root
IIRC the standard for 50W Marshalls has always been 500mA fast blow. Personally I would be loath to use a slow blow fuse on the HT, with or without SS rectifier, in any design.
Lately I have only used a fuse in the power section on the CT of an old vintage OT I do not want to lose. 200mA fast blow. This in a 50W amp. I also used a 500mA slow blow on the CT of the PT too, as it was also vintage iron. These are inline fuses inside the chassis, I also use a 2.5A slow blow on the PT primary.
I've used 200mA SB in the secondary CT-to-ground of my 18W design. I'm pretty sure this is not the right way to do it, but definitely took it off a schematic as i knew very little about building amps back then.
i'm omitting the fuse on the secondary entirely in my soldano atomic 16 build though.
In the interest of full disclosure, I am Animal Factory Amplification.
Dingleberry
I have been taught by my amp mentor that T stands for Time Delay.
I have been using T for MAINS fuse and fast for HT fuse.
-T
-T
Yeah same diffDingleberry wrote:I have been taught by my amp mentor that T stands for Time Delay.
-T
