I followed my other LTA120's the best that I could and now upon power up it blows fuses. I checked the polarity of the Filter caps (-) is to ground. What i'm finding strange is possibly the PT is wired wrong. Here is what I have going on.
The Power Transformer is model PX3618
one side has
two black wire (city power - in )
two Green wires ( Heater voltages )
the other side has
two Red wires ( red to red tests 833vAC )
one Yellow with a red stripe center tap
one White with a blue stripe ?
the other LTA120 have the Yellow to Ground and the White running off to the PCB.
I've disconnected the PT from the amp no wiring shorts to ground all grounds go to the ground buss.
When I wire the PT I get continuity threw all the legs to ground and each other, but it works out of the amp.
It has to be something to do with the White/blue stripe wire.
Where am I futzing this up? A schematic sure would be nice, but no dice they where printed on drafting paper and over the years the pile shematics stuck together and descentigrated the early years.
