this is the cabinet of my amplifier, it is not complete because they lack the corners, and the chassies must be finished.
I'm waiting other material and Trafo.
						My cabinet
My cabinet
						- skyboltone
Re: My cabinet
Way to go Sergio. Correct side up too!
Re: My cabinet
Have intentionally positioned the chassies below.
Thanks for your advice Skyboltone.
Re: My cabinet
OTHER PHOTO
						Re: My cabinet
Chassie photo
						Re: My cabinet
another photo
						Re: My cabinet
Looking good! won't be long now before it sings.
www.RedPlateAmps.com
Re: My cabinet
"Ben fatto, Sergio!"  Nice work!
Mark.
									Mark.
"...there are flying v's and then there are the ones shaped like peanuts..."  - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
@MalinAmps
Re: My cabinet
Thanks Mark, but I'm not sure of my voltage , it seems to me high!..
						Re: My cabinet
V1 is a little high - but might be OK - some amps sound great there, others sound better at 190v. Ditto for V2 it's probably good but might sound even better a little bit lower. Are you using a 150K resistor to ground at B+5 (FET simulation resistor)? If not, add one. If you are try 120K or even 100K to listen to the difference. You could also adjust the resistor between B+3 and B+4 - I like 22k but have used 27K in the past. I like 2k2 between B+4 and B+5.
The other tube's voltages look great.
