Gil
I can measure voltages and post them later, sure. However, this uses a TF135 PT, so it has ~440 VDC on the power tube plates, etc. -- so I don't expect any surprises in the voltage department.odourboy wrote:Niec clean work - looks fantastic!
When you're finished taming this beast, I hope you'll post the vitals (tweaks, trimmer settings, voltages....).
Cheers!
Dave, I have to qualify a few things: is your amp a Blues Master HRM? If not, i.e. if you have a Skyliner EQ, then my boost approach will not work in your amp.stelligan wrote:Thanks for posting this. Of special interest to me is the detail you have shared regarding the wiring of your PAB. This is an area I am still tinkering with to get it to be more usable for me in my HRM. I find I almost never use it on the clean tone and always on the OD tone with a midboost as well. Does your method yield not a more subdued volume jump than standard on the clean side, but a less harsh tonality? Is that "not subtle but mellow"? Fabulous looking build by the way.
thanks,
Dave
Gil,3. I use a .001uF (orange disc on the HRM board, mounted on eyelets) bypassing OD2 Rp to tame the top end "hardness" a bit. Makes the usable treble control range on the HRM wider.
Not yet... I'm just bringing the amp up now and annotating the changes... I'll post the updated schematic in a couple of days.mlp-mx6 wrote:Mark,
Is your schem updated with that change?
Well, the treble bleed is something I use in my non-HRM amps and it hangs to ground AFTER the 150K output resistor. So it is placed after the .005uF coupling cap and after the 150K resistor, where it joins the "lead master" volume control.Fischerman wrote:Gil,3. I use a .001uF (orange disc on the HRM board, mounted on eyelets) bypassing OD2 Rp to tame the top end "hardness" a bit. Makes the usable treble control range on the HRM wider.
In another recent thread you mentioned a treble bleed off of the 'top' lug of the Lead Master. Is the Rp bypass cap mentioned here used instead of that...for a similar effect? Is it an 'either/or but not both' thing?
Purty build!
EDIT: I'm glad you mentioned the bass ON/OFF thing. A 1M-L seems extremely hard to dial in there...it seems a 500K-A would be better.
Very cool, it validates my ears. Thanks Mark.mdroberts1243 wrote: Hi Gil,
In my amp I found "mega boost" and the 470k to be too much as well... I went for a +6dB boost and settled on a 72k ohm resistor... the 82k gave me 8.4dB, BTW.
