ODS-101-HRM BOM
ODS-101-HRM BOM
I'm putting together a BOM for the ODS-101-HRM schematic.  I may or may not end up using it but I figure enough people ask for 'em so I might as well. Most of the work was done for me - I forget where I got the file this is based off of.  Anyway, I'm going to get a generic "these are the parts you need" list without specifics on brands and sourcing, then if I get around to building myself one I will post one with more specifics.  I'm not 100% done but here's what I've got so far.  Note that I used 100W specific values.
						Re: ODS-101-HRM BOM
Never mind.
Re: ODS-101-HRM BOM
Actually the point of this first BOM is NOT to provide part numbers.  Any BOM with specific part numbers is going to need to be edited before it can really be used, as part numbers change and no two people are going to have exactly the same idea about what parts should go into the amp.  The idea was just to make a complete list of everything required according to that schematic.
Is there an HRM specific layout that corresponds to the ODS-101-HRM schematic? It's not really that big a deal as just about any D-style layout that's reasonably close to the real thing should work ok.
Re: ODS-101-HRM BOM
Okay. Then I won't add suppliers and part numbers. Sorry.benoit wrote:Actually the point of this first BOM is NOT to provide part numbers. Any BOM with specific part numbers is going to need to be edited before it can really be used, as part numbers change and no two people are going to have exactly the same idea about what parts should go into the amp. The idea was just to make a complete list of everything required according to that schematic.
Re: ODS-101-HRM BOM
Nah dude, that would be totally fine if you wanted to do that, I'm sorry if I wasn't clear.  I was just saying that MY intent was to get a list together first and THEN worry about part numbers, but I actually think it'd be cool if you wanted to do that while I work on this.  Go for it.
