New ODS build with pictures
Dumble schematics, designs, pictures. Only members may post files here.
airniles
Re: New ODS build with pictures
Post by airniles »
Hi Sven,
Look at the topic of ic-racer, which includes the layout and the schematics.
The #124 from 1984 is the one I used as a reference.
https://tubeamparchive.com/viewtopic.php?t=5719
The original schematic and pictures of the #124 is of course here:
http://www.roblivesey.com/dumble/ (under topic Dumble #0124/ )
Hope this helps
airniles
Post by airniles »
Hi strato17,
This is no dump question, I bought the chassis from Natchanis at:
http://vasinguitaramp.tripod.com/id1.html
erwin_ve
Post by erwin_ve »
Thats's a nice build.
I see you used other (than that came with the kit) filter caps . Tranny's are Ceriatone? What value did you use for the trimpot before the Od(v2a)?
airniles
Post by airniles »
Thanks Erwin,
Yes, I used different filter caps ( as close as I could get to #124 ).
The Tranny's are from Ceriatone.
For the trimpot I used A 350K version I bought from Antique electronics
http://www.tubesandmore.com/ (part number R-VT350KL).
Are you building an amp at the moment?
If you like you can try my amp (since you live in the Netherlands as well)
strato17
Post by strato17 »
airniles wrote:Hi strato17,
Upon ordering the chassis, how long did it take you to recieve it?
airniles
chassis
Post by airniles »
It took about 2 weeks.
He sends you a tracking number, so that you can follow the package.
It was wrapped perfectly when I received it.
