point to point D-lator build in hammond rack chassis
- Funkalicousgroove
Re: point to point D-lator build in hammond rack chassis
I just copied the original as closeley as possible without using PCB's.
The tube is mounted as the original, and it is plenty snug. Since it is rack-mounted and not subject to cabinet vibrations it should be just fine.
- Funkalicousgroove
Here's the original
- Funkalicousgroove
Here's the original
- Funkalicousgroove
here is the power supply
Yeah! Funk is da MAN!
where do you get those wonderful toys.
"In this world you will find hardship and trials; but take heart, for I have conqured the world."
John 16:33
John 16:33
Thanks a million for posting this - very helpful
www.RedPlateAmps.com
- Funkalicousgroove
Sure thing!
Wooo! Thanks for this Brandon!
WOOOOOOOOO!!!!!!!!!!!!!!
67:1
resophonic1
Brandon,
Thanks for sharing your build and the additional info!
What kind of shielded wire do you use? And can you notice any change in sound (less highs)?
Tommy
Tommy
- Funkalicousgroove
I use an ultra low capacitance cable (11pf/ft) and it has "more highs" than the typical RG180 type cable.
where do you buy it?
Tommy
Tommy
- Funkalicousgroove
How much do you need? I have a 1000ft roll I can break you off some or you can get your own roll from www.gepco.com it's the digital audio cable. 2 conductor, 24awg.
zephyrblau
